'05 Taurus Computer Module Location
Old 02-20-2006 | 10:50 PM
stanshepp's Avatar
Default '05 Taurus Computer Module Location
I just bought a used Taurus and I do not know the keyless entry code as programmed by the factory. It is supposed to be located on the COmputer Module, but I do not know where that module is located. Under the hood? Under the dash? Driver's side? Passenger's side? In the trunk? Does anyone know? If so, could you please tell me?
Thanks!
Old 04-13-2006 | 04:15 PM
WASLYH's Avatar
Default RE: '05 Taurus Computer Module Location
[8D]
i hope i can help...had the same problem( see all my posts 2day)
the 'puter should be under and to the left of the steering column...
get under there w/flashlight and look on the right side...it should be there
little white tag with 5 digit code...
Old 04-14-2006 | 07:59 PM
stanshepp's Avatar
Thank You! Thank You! Thank You! That worked! Thank You!
Old 05-12-2006 | 05:29 PM
WASLYH's Avatar
been gone 4 awhile...no problemo...glad it turned out 4 u..
mnpc7v7
04-30-2017 12:22 AM
MarcEMarc
03-30-2009 04:48 PM
iward3
12-29-2008 12:12 AM
Country Man
11-06-2008 12:08 PM
