1994 taurus gl
Old 05-06-2011 | 02:26 PM
fordfreak98584's Avatar
Default 1994 taurus gl
I have a problem with the wipers. they stop midway up when turned off. I have been told that it is either the wiper control module or the wiper motor. 2 questions: Which one would it be, and where would I find the control module if that is the problem. Have already replace the switch. Any help would be greatly appreciated. Thank you. mikelauzonbarr@yahoo.com
Old 05-06-2011 | 07:11 PM
way2old's Avatar
Usually, I said USUALLY, it is the wiper motor that is the cause of that problem. It actually needs to be diagnosed to be sure, but if you are a gambler-----------
Old 05-06-2011 | 08:25 PM
I agree with way2old. There are wiper fingers in the drive section that wear from rubbing on the printed circuit and sometimes break preventing the wiper motor from going to the park position and the usual remedy is to replace the wiper motor.
Old 05-07-2011 | 12:24 PM
thanks for the help guys, really appreciate it. Gonna go the cheap route and try the local junk yard and see if it works.
Old 05-07-2011 | 08:07 PM
way2old's Avatar
Good luck. Let us know the outcome.
Old 05-13-2011 | 12:51 PM
thanks all. it was the wiper motor, and now it works fine. really appreciate the help. $15 at the junk yard.
Old 05-15-2011 | 04:30 PM
way2old's Avatar
Thanks for the fix post. A lot of posters forget to do that. Thanks again.
beads8
04-26-2006 11:56 PM
canadianwhiskeygrl
01-09-2006 07:09 PM
canadianwhiskeygrl
01-09-2006 07:09 PM
Evomaniac87
10-16-2005 09:29 PM
roger.e
05-22-2005 12:37 PM
Quick Reply: 1994 taurus gl
