1999 Ford taurus dont want to kick over
Old 03-18-2013 | 08:28 PM
rbailey's Avatar
and about the cam synchronizer,i did not remove the cam synchroniser i just took the two little bolts off the sencor and replaced the censor
  #12
Old 03-18-2013 | 08:31 PM
rbailey's Avatar
oh about the camshaft synchronize i just took the two small bolts out and changed the sensor only i did not mess with the camshaft synchronize.
  #13
Old 03-21-2013 | 03:06 PM
rbailey's Avatar
pulled everything off again... lined the timing chain.. once again.. it is at tdc.. and still nothing.. lost if any help would greatly be appreciated!
  #14
Old 03-21-2013 | 05:55 PM
With the engine at TDC , #1 piston at the top of the compression stroke, #1 piston is the 1st piston on the passenger side against the firewall, the mark on the crankshaft sprocket should be at the 12 o' clock position and the timing mark on the camshaft sprocket should be at the 6 o' clock position.
When you removed the chain were the timing marks lined up then?
Is the cam sprocket in the correct position on the camshaft? Pin OK?
After correct assembly were you able to verify that the cam synchronizer is actually moving when you rotate the crankshaft?
henryts77
12-04-2013 09:07 PM
readcit
12-12-2010 12:27 PM
arch3angel
01-04-2008 04:27 PM
bardo
04-17-2007 10:57 AM
harleybadboy2
05-01-2005 12:22 PM
