2000 taurus 3.0l 24v engine diagram
Thermostat — 3.0L 4V
Removal and Installation
Drain the engine cooling system.
Disconnect the lower radiator hose from the water outlet adapter.
(first thumbnail here)
Remove the bolts, the water outlet adapter and thermostat.
Remove and discard the O-ring seal.
(Second thumbnail here)
To install, reverse the removal procedure.
Similar issue but different
I own a 2001 Taurus Duratec and the above diagram does not look like my configuration. I'm having a hard time finding the part that gets bolted onto the Thermostat housing. Help?
Ken
2001 SES
275,000+
Ken
2001 SES
275,000+
