2001 taurus
Old 07-16-2010 | 05:53 PM
rodger's Avatar
Default 2001 taurus
i have 01 taurus with rough idle code po302 #2 cyl.put plugs wires coil new injector checked most everything runs fine when driving
Old 07-16-2010 | 07:25 PM
rodger's Avatar
Default rough idle
more on my post 01 taurus #2 cyl. only has 80# compresion
Old 07-17-2010 | 02:05 AM
Exclamation
Not quite enough..
Whats the mileage, and comparable comps?
Old 07-17-2010 | 05:20 AM
rodger's Avatar
Old 07-17-2010 | 06:13 AM
Now you know where the problem is, do you have access to a leakdown tester? That test will help determine if you have a bad valve,head gasket,worn rings etc. I don't believe you have a questionable lobe on the camshaft, but at this point anything is possible. Will watch thread to see what you decide. Good Luck, hanky
Old 07-17-2010 | 10:01 AM
rodger's Avatar
Default 01 taurus rough idle
checking leak down test next
randgvan
04-09-2007 01:37 PM
SR20S13
01-22-2007 01:27 AM
squirrelmasta333
11-27-2006 03:07 PM
chaud
02-19-2006 02:17 AM
BDKING618
10-24-2005 09:15 PM
