2002 ford taurus pully noise
Old 10-09-2010 | 10:48 PM
FordForLife2009's Avatar
Default 2002 ford taurus pully noise
When I first start my car in the morning sounds like a pully is loose and make a squelling noise when im driving. Only happens when I accelerate. But when the engine warms up the noise stops. Can it be the idle control pully?
Old 10-10-2010 | 04:38 PM
As you may be aware there are several pulleys that the one belt rotates.
One of the ways to pin down which pulley is possibly making the noise is;
release the tension on the idler pulley and remove the belt from any one of the pulleys. After you release the tension idler you should be able to rotate just about all the pulleys except the main drive pulley at the lower part of the engine(crankshaft).
Usually the culprit can be determined this way. You have the alternator, power steering, air conditioner and idler pulleys to check. Just make sure the belt routing diagram is present somewhere in the engine compartment before you remove any belt.
Would be nice if you shared your result with us . Thanks
Old 10-13-2010 | 04:53 PM
Yeah I did undo the belt as you said and checked each one of the pullies and it was the idler pully the thing was shot so I replaced it and everything is perfect. Thanks for the help
Old 10-13-2010 | 05:23 PM
Thanks for the reply. Its sad that more folks don't reply as to whether our suggestions are helpful or not.
hdluvr
12-27-2017 03:13 AM
Johns Ranger
10-20-2009 02:03 PM
haledonoem412
02-11-2009 11:15 PM
fuzion03
12-22-2007 04:24 PM
greasemonkey
09-18-2006 11:44 PM
