2004 Taurus V6 Trouble Code PO174
Old 09-14-2007 | 07:01 PM
obiejuan's Avatar
Default 2004 Taurus V6 Trouble Code PO174
Problem Solved............I have a OBD2 test result showing a PO174, which is a "System to Lean (bank 2) ". I have been unable to locate info on this code. Can anyone assist with what I can do mechanically to repair this. Check Engine Lightcomes back on soonafter clearing with OBD2. Thanks for any help! PeteUPDATE: I was able to locate info directing me to MAF sensor area and Vacuum Lines. I was going to remove MAF sensor to check when I noticed one of the vacuum tubes leading to/from the MAF sensor was disconnected. I reconnected and cleared TC. The cars runs 100 times better and no Check Engine Light!
dover6811
10-24-2014 08:37 PM
Bronco76Ranger00
11-08-2009 09:24 PM
ghoghunter
08-23-2009 07:53 PM
argneco
03-25-2009 07:04 PM
5. Slow
12-22-2007 12:08 PM
