95 Taurus input speed sensor location?
Old 08-07-2011 | 03:10 AM
joepenn's Avatar
Default 95 Taurus input speed sensor location?
Any idea of the location of the input speed sensor?
Thanks in advance for any & all help.. sinc. Joe
Old 08-07-2011 | 06:47 AM
It is located on the driver's side of the trans just above the half shaft going out to the wheel. It bolts to the trans with one bolt. If you are planning to replace it , tighten it to only 80-106 inch pounds. It is also called the turbine speed sensor, if that is what you are looking for.
Old 08-07-2011 | 01:21 PM
joepenn's Avatar
That's the one! and the source of all the troubles. Thanks for that added info hank cause I would not have known about the torq. specs.
Old 08-07-2011 | 01:29 PM
joepenn's Avatar
Hank is there a gear on this sensor that I should possibly think about changing also?
Old 08-07-2011 | 04:24 PM
There should be no gear on it.
Old 08-08-2011 | 07:55 PM
joepenn's Avatar
It's done, Hank Thanks for all the help very much appreciated.......
djtragik951
04-07-2008 12:06 AM
kennylogel
12-26-2007 11:48 PM
advisual
08-10-2007 06:31 PM
gmm
07-22-2005 12:09 PM
