96 Ford Taurus G L Fuel Pump
Old 03-12-2009 | 09:03 PM
tobacmon's Avatar
Thanks again for your help--It was the pump and now the ford is back on the road---It's always nice to have a lift (friend has residential garage w (2) lifts ) and was a quick fix. I did notice the splice made in the line going to the connector. I heard someone post here that this would also cause failure and tpo make sure the splice was good--it was-----Pretty nice of Ford to put a splice before the pump connector--Go figure.
There is one more problem and hope I'm not being a pain---My Air Bag light inside / dash is flashing the code 5 & 1 =51.---From what I understand this is a fuse link---Is this true and if so where is it located. My buddy told me he thinks it's in a module over the steering column in a black box.(Air Bag module) Does this mean I have to replace the whole module or is it just a fuse---Please explain if you know what I'm talking about..Again thanks!!!
  #12
Old 03-13-2009 | 12:06 AM
The air bag diagnostic monitor (module) is behind the radio/integrated control panel.. If your getting a LFC 51 then the 'internal' fuse inside the monitor is blown.. It's not a servicable fuse and the monitor will need to be replaced.. 'BUT', plugging in a new diagnostic monitor if any of the system components are shorted to ground, harness issues, or the bags have/had been deployed prior (?) with only some of the parts replaced can possibly take out the fuse again.. Code 51 means that the system was shorted intermittent/temp, and LFC 13 flashed would be for a continuing short to ground as a higher priority code..
  #13
Old 03-14-2009 | 06:39 AM
tobacmon's Avatar
Thanks again for responding---What is the proper step by step procedure I should take to remedy this error? Can pull the radio to access the Module? I am sure you will know what to do---LOL Will a diagnostic PC tell me where to start? Or is there an easier method--anything to save $$$--Thanks!
  #14
Old 08-30-2009 | 07:00 AM
tobacmon's Avatar
This was a Bad Fuel Pump--replaced and working great---Thx. Hayapower!
  #15
Old 05-03-2011 | 01:42 PM
robdaddio69's Avatar
Default 96 taurus
my car will start then cuts right off....checked filter it was fine......while i had filter off i turn key the pump kicks on for a sec shoots gas out then cuts right off....is the pump definately my problem?pump is $123.00 n is a good little job to replace.......please help
jozepy24
07-13-2019 06:21 AM
fordexpedition2006
04-21-2017 06:23 PM
Spaznaut
05-24-2014 03:10 PM
robbyradio
06-17-2013 05:10 PM
grumpydave
01-18-2008 04:15 PM
