97 ford taurus cranks but won't start when engine hot
Old 03-18-2012 | 07:43 PM
Jacki Englehardt's Avatar
Default 97 ford taurus cranks but won't start when engine hot
Starts up fine in the morning or after cooling down. Yesterday while running errands around town, it would crank but not turn over after the engine was hot. In the past 1-2 months, the idle has gotten a little rough sometimes (maybe when engine is hot). Sometimes felt like it might stall while sitting at a red light. Any ideas about what the problem is?
Old 03-19-2012 | 04:38 AM
If you can do this,
When warmed up and it won't start,dump some cold water on the crank sensor. If it starts up right after that , the sensor is going south, replace it.
Do you have any way to check the fuel pressure?
Old 03-21-2012 | 03:48 PM
If you can do this,
hanky -- you were right, it was the crank sensor. Thank you.
oldmanonhill
06-11-2014 05:28 PM
BillSinclair
03-08-2014 07:44 AM
Alx717
03-17-2009 09:20 PM
krobman
11-29-2006 05:09 PM
HERE
11-25-2005 01:52 PM
