97 Taurus GL Coolant Leak
Hello, got home yesterday and noticed a trail of coolant down the street and into the driveway. I looked under the car and saw it was still draining out. The temperture gauge was normal all the way home so I don't know when it started. My first thoughts were heater core plugged or water pump bad as these have caused leaks on me before with other vehicles. But the leak was around the center of the vehicle. I thought it was running down from somewhere else so I waited until this morning when it was cool to have a further look. I added water into the tank and started the engine. It was still pouring out around the center of the engine. (A pretty good leak) I turned it off and started to check it out. No leaks apparent anywhere near the water pump or the heater core area. The coolant appears to be coming behind some sort of panel right next to the oil pan. Next to the oil pan underneath the car towards the drivers side there is a metal plate, right between the plate and whatever is behind that is where the water seems to be coming from. Does anyone know what is behind that plate. I went back almost 2 years worth of posts to find anyone who has gone through this and I fear it might be freeze plugs? Is there a way for an average joe to do this? Also, a little history. Since about Feb or March, every now and then, when the car would be idleing, like at a long stoplight or drivethrough, the temperature gauge would start to rise and I would lose heat inside the car. It would never overheat, the fans would be running almost constant and the gauge would go up to about 3/4. I would add some water and it would be back to normal. I could never find a leak or any visable signs of a leak but it was going somewhere. Maybe I just missed the leak. But this one is impossible to miss and does anyone have any idea what might be causing this. Thanks in advance for any input.
RE: 97 Taurus GL Coolant Leak
I have had coolant leaks on my 97 Taurus several times and it never seems to drip directly below the problem area. It always seems to be diverted by something under the hood. One problem I had is the coolant reservoir. It is under pressure and can split at the seam. When this occurs, it tends to leak occasionally but I experience the same regarding the coolant temp you are having. It didn't leak constant to cause it to lose all the coolant and took a while for me to find. This tended to drip between the resevior and the bumper.
The other leak I had was the hoses. Apparently ford redesigned the coolant hoses after they made this model. The original went from the reservior to the firewall. The new one has a bypass hose between the resevior and the firewall. The T where the bypass comes in leaked. I had to replace this twice.
The other leak I had ended up being the water pump. This time it over heated and I had to replace the water pump, freeze plug and 3 sensors. That was a very costly fix. The ford dealer also replaced old configuration of hoses with the new configuration which I didn't realize the reconfiguration until after the fact. I could find the right hoses when it started leaking a few years later. The dealer's computer showed something different from my configuration. I finally found a ford dealer that noticed a comment in the notes section that said if the configuration does not match the customers hoses, to order a specific part # instead.
