98 Taurus with coolant leak.
I have a 98 Taurus that seems to be leaking coolant under the car on the passenger side. I have also noticed "smoke" and a bad smell coming through the air vents. Have done some looking around and seems it might be my heater core. I have not noticed any coolant on the passenger floor board however. Its all be on the outside. So is it the core or a leak somewhere else maybe?
If it is the core i was wondering if i would put my bypass in place till i have the time to replace the core. what i have read about it said i have to take the dash off and it take all day. Its summer and i don't need the heat right now so was hoping i could do a bypass as a short term fix. Thoughts or how to on this?
What about one of the LeakStop products?
It can usually be bypassed with a piece of 1/2 in. copper tubing.
As you know stop leak is like a band aid, sometimes it becomes a permanent band aid.
It might work to plug the leak, but it will also leave the door open for plugging things you would not want to have plugged.
