98 TAURUS HARD BRAKE PEDAL AT TIMES
Old 02-06-2008 | 08:45 PM
jhatten's Avatar
Default 98 TAURUS HARD BRAKE PEDAL AT TIMES
most of the time the brake pedal is mushy and makes a ssshhhhhhh sound when you press it down. you hear air coming from under the dash and when you push it further it makes a whistling noise, very loud. At times while driving the pedal is very very hard. also when the pedal is mushy it travels 3/4 of the way down before the car starts to brake. there are quite a few other wierd problems with this car but this one is more important right now. any help would be appreciated thanks all
Old 02-07-2008 | 02:16 AM
jr78's Avatar
Default RE: 98 TAURUS HARD BRAKE PEDAL AT TIMES
The hard pedel and ssshhhh sound makes me think you have a bad booster. The soft/ mushy pedel is most likely another issue. I would replace the booster, bleed the brakes and adjust the rear brakes.
Old 02-07-2008 | 10:58 PM
jhatten's Avatar
Ibet you are right on the money.I bought an aftermarket cardone booster today $ 56.00. This car was driven very hard for about a year, it was used for paper delivery. It was about 70 to 80 hard miles per day all stop and go I don't think the rear brakes are doing much at all. also the parking brake doesnt work. i'll try the booster saturday or sunday. i'll try to take a few pics during the process and post the result when i'm done. if anyone has any tips please feel free to chime in. thanks
john
Old 02-08-2008 | 01:19 AM
jr78's Avatar
Take your time on the booster, it can be hard to get the studs through the firewall and the pedel mount. It helps sometimes to have a helper inside the car to get things aligned.
Old 02-08-2008 | 08:30 AM
jhatten's Avatar
very good idea, thanks
Old 02-13-2008 | 03:20 PM
jhatten's Avatar
THANKS FOR THE REPLIES, I REPLACED THE BOOSTER THIS PAST WEEKEND. IT WAS NOT THAT BAD OF A JOB, BUT IT DID TAKE MORE TIME THAN I FIGURED. ALL OF MY NOISES ARE GONE AND THE CAR STOPS SO MUCH BETTER. I AM ALSO GOING TO REPLACE THE REAR SHOES AND TRY TO FIGURE OUT WHY THE PARKING BRAKE DOESN'T WORK.
Ejackson
04-21-2015 03:25 AM
jineson23
10-27-2008 04:41 PM
oscar7777
09-08-2006 01:22 AM
gergo
08-25-2006 04:50 AM
jwolfe815
01-17-2006 10:37 PM
