A/C cause overheating, why?
Old 05-01-2010 | 11:46 AM
ikala476's Avatar
Unhappy A/C cause overheating, why?
Got problems with overheating. Change water pump and thermostat, but problem continue. Car runs ok until I start the A/C, the temperatures go all the way up in less than 5 minutes after the A/C is on I turn it off and temperature goes to normal.
Old 05-01-2010 | 11:47 AM
way2old's Avatar
Are the cooling fans work properly?
Old 05-01-2010 | 12:21 PM
FordMan59's Avatar
Check to see if the radiator fan is coming on when you turn on the a/c. It should.
Old 05-03-2010 | 10:24 AM
ikala476's Avatar
Default Looks ok for me
The two fans start ok, what Im not sure if they are working ok. I notice they turn a littler slow. Thanks
Old 05-04-2010 | 06:49 AM
FordMan59's Avatar
Some cars have a two speed fan. Your fans may not be working right on the high speed causing the overheating. It could be a bad fan relay causing the fan not to run on the high speed.
askedofgod
07-18-2015 12:53 PM
ben boysis
12-10-2012 01:40 PM
holbrom
04-07-2011 05:49 PM
Adams
01-08-2011 05:07 PM
Sooner0233
06-17-2008 12:26 AM
