A/C question 01 taurus
Old 03-29-2007 | 02:17 PM
enlowkd's Avatar
Default A/C question 01 taurus
having trouble with ac cools and heats when it wants to pulled codes from ac found 051 and 053 cannot seem to find proper code definitions for these two codes any help would be appreciated
Old 03-29-2007 | 04:33 PM
goinstrong's Avatar
Default RE: A/C question 01 taurus
If you have a book are there any code definitions for those numbers?
Old 03-29-2007 | 04:39 PM
enlowkd's Avatar
i dont have a book just bought car 2 wks ago was trying internet before buying book
Old 03-29-2007 | 06:02 PM
Self Test (hard) fault 051.... Run Time (Intermittent) fault 053
Code description.... Solar Radiation Sensor Open
Old 03-30-2007 | 03:14 AM
goinstrong's Avatar
My AC don't have a solar radiation sensor and I'm glad it's old once again. Besides - instead of pretending - why not call it a heat sensor? What solar radiation is really penetrating the hood? Or is this a cabin sensor to detect heat transfer through the glass?
Old 03-30-2007 | 04:34 AM
enlowkd's Avatar
thanks for the info now the job of getting to it and finding one
Old 04-26-2007 | 05:15 AM
enlowkd's Avatar
finaly replaced sensor still will not cool when hot out cool out compressor willl run and make ice cubes get warm compressor cuts off and will not comeback on regard less of temp settings freon seems to be ok by gauge
Old 04-26-2007 | 05:50 AM
enibum's Avatar
I was curious, what does your engine temp look like when the A/C won't work? I think some cars have built in protection that will not allow the compressor to kick in if the motor temp is too high.
Old 04-26-2007 | 03:13 PM
enlowkd's Avatar
according to gauge on dash never more than center of travel
Old 04-27-2007 | 11:24 AM
Use Common Sense's Avatar
I'm probably blowing smoke out in left field on this, but are your cooling fan(s) working properly? I believe that one of them is tied into the A/C system to come on when setting at an idle state such as in stop and go city driving. This keeps air flow across the condensor. Time to get a copy of the electrical shop manual and start tracing electrons. Good luck.
