cluster lights inop
cluster lights inop
bought 02 lx about 6 monthe ago. recently, major problem with instrument cluster lights. when headlights turned on, cluster is dark, only thing lit up is blinker arrows. sometimes after several hours of driving lights will come on. have not replaced anything yet, and, if dim the dash lights, center hvac cluster will blink with blinkers. with rheostat switch turned up, hvac lights will not blink. any ideas? wife is second owner, no apparent signs of collision or flooding.
RE: cluster lights inop
One of three things. Some "genious" wired an aftermarket radio or installed a part wrong or a dual filament bulb half-blew and crossed one filament onto the other creating wierd grounding problems. Or could be a bad ground (including fried solder from a circuit board or a wire or fuse misplaced).
Hi. I had exactly the same thing happen to me. It turned out the cluster had a bad ground and had to be replaced. I have an SES '02. I remember reading about it some time ago and also other members had same issue. I am not the one who changed the cluster, but according to what I understand it is an easy job but very long as a lot of stuff has to be moved to get to it. Good luck.
