code for keyless entry pad
Old 03-21-2006 | 12:05 PM
flboy1025's Avatar
Default code for keyless entry pad
Hello all,
I have been everywhere with no help. I have a 2005 Ford Taurus SEL which has a keyless entry pad. I cannot find the manufacturer's code. Any help would be greatly appreciated.
Thanks.
Old 03-25-2006 | 10:38 AM
billybroncojr's Avatar
Default RE: code for keyless entry pad
I have a 95 with keyless entry and the code for the keypad is on the underside of the trunk lid.
Jeff
Old 04-13-2006 | 03:02 PM
WASLYH's Avatar
on some models( mine is a 2001) you can find the code,if not on the trunk support arm on the side of the computer which should be to the left of the steering wheel column..
you are gonna have to run the driver's seat all the way back,scrunch under the steering wheel shaft and use a flashlight to read the code of of the right side of the 'puter...
hope this helps...
JJMOSOL
10-04-2012 12:56 AM
pkd7423
07-14-2008 04:01 PM
dandd1214
09-15-2007 04:19 PM
97EB
08-21-2006 02:17 AM
dandd1214
05-07-2006 03:30 PM
Quick Reply: code for keyless entry pad
