Engine Chirping Noise Diagnosis Tip
Old 06-15-2014 | 05:38 PM
makuloco2000's Avatar
Default Engine Chirping Noise Diagnosis Tip
This is still a commonly misdiagnose as a belt chirp especially on the 3.8l mustang but can sound like a general engine bay noise in the Explorer 4.0L OHV and Taurus 3.0L OHV especially. So before replacing belts and pulleys take a look to make sure this is not the actual source of all that noise people confuse the two all the time.
Quick Tips: #18 Ford 3.0L 3.8L 4.0L 12v Engines Chirping Noise - YouTube
Old 06-16-2014 | 05:17 AM
Use Common Sense's Avatar
Good video and explanation. Same thing on the 3.9 and 4.2 Essex engines. I was actually getting an occational idle stall and periodic harsh tranny buck before mine started chirping. This happened on my way down to AZ. As soon as I started hearing the chirp, I replaced mine when I got to our house in AZ. Problem solved.
Old 06-16-2014 | 02:52 PM
I have only had that buck stall issue on the 3.8l too which is weird cause I have seen allot worse sounding ones on the 3.0L.
Old 06-17-2014 | 12:30 AM
Mine would chirp 2-3 times every couple of minutes or so, but not very loud. When I pulled it, it was pretty stiff turning it by hand and would actually bind up and not turn by hand unless I turned it counter clockwise and then back clockwise. I'm at about 159,000 miles and the 4.2 still runs like new and fixing to roll down to Florida for a week.
makuloco2000
05-22-2014 11:53 PM
No Harley Here
01-01-2008 09:59 PM
dustris
09-19-2007 02:14 PM
woofan6
06-28-2007 07:57 AM
DKEYSER
02-05-2007 01:54 AM
