Ford Ignition Coil Pack Heat Failures & Misfires When Wet
Old 08-25-2014 | 02:07 PM
makuloco2000's Avatar
Default Ford Ignition Coil Pack Heat Failures & Misfires When Wet
Had a very good example of how this particular coil pack fails from heat over the years. The misfire may be intermittent or only when wet out. Either way this particular coil pack style which is used in the Taurus Windstar and 4.2L F150 all fail the same way. If you have a misfire you are fighting I urge you to take a closer look at the coil pack as shown for these common signs.
SixxiA
01-29-2014 09:42 AM
Cowboy_80
04-29-2008 01:34 AM
yellowbird
03-07-2008 12:09 PM
rlevy64614
06-08-2007 09:55 PM
jquay
01-24-2006 10:58 PM
