Ford Trouble codes definition and possible causes (Free Android App)
Old 03-25-2015 | 01:52 AM
red car's Avatar
Default Ford Trouble codes definition and possible causes (Free Android App)
When You use OBD2 diagnostics tool to read DTCs your vehicle.
If DTCs lack of definition or possible causes.
You can down this android app to your phone. It support over 190,000 DTCs.
I'm use it and it have more definition and possible cause for Ford and other vehicle.
This app helpful for you about fast repair car.
Name App: OBD2 Codes Fix Free
Author: OBD High Tech
>>>Click here to down it on Play Store<<<
Old 04-27-2015 | 07:54 PM
Skyhawk's Avatar
Thanks for that good information. I would add; Do not assume that the component mentioned in a DTC is a bad component. A DTC is triggered when the computer does not get the signal it is programmed to expect in a given set of circumstances, e.g. idle, accelerating, etc. The cause of the DTC may be a bad component, e.g. a sensor, but it can also be a bad connection due to corrosion or forgotten during reassembly, or it may be a pin-out at another connection somewhere else in the harness, or it may be a shorted or open wire in the circuit. Intermittent problems and codes are often connection related, e.g. ground connections. Hope this helps.
Old 04-28-2015 | 03:58 PM
You need to be careful with Ford misfire codes because FORD PCMs have a habit of fibbing when they indicate which cylinder is misfiring. They don't always tell the truth(correct cyl). Quite a few times it was an adjacent cyl.
ezequielc
10-24-2012 04:11 PM
Bronco76Ranger00
11-08-2009 09:24 PM
lue_driver
09-16-2005 06:48 PM
lue_driver
09-10-2005 03:12 PM
