Fuel gauge malfunction
Old 07-29-2006 | 11:12 PM
rbech's Avatar
Default Fuel gauge malfunction
My 2001 Taurus's gauge is not working. It fluctuates constantly from empty to full and in between. My fuel pump(in gas tank) needed replacing and the fuel sending unit is part of the pump unit according to my Ford dealer. This did not fix the gauge problem unfortunately. I checked the fuses. If it is a grounding problem, where would I look? Getting at the gauge from underneath the dash is virtually impossible. Any suggestions?? Thanks!
Old 07-30-2006 | 02:00 AM
Mulletman's Avatar
Default RE: Fuel gauge malfunction
Is this vehicle a "Flex Fuel" model by chance? If it is, the the FF Module under the dash is probably the culprit. If it is not a "Flex Fuel" model, then we will need to investigate further.
Old 07-30-2006 | 02:13 AM
rbech's Avatar
Thanks for responding! The car is not a flex fuel so the mystery continues.
Old 07-30-2006 | 07:18 PM
way2old's Avatar
There is an anti slosh module located in the dash that may be the problem. Its job is to keep the needle from bouncing around.
Old 07-30-2006 | 11:16 PM
rbech's Avatar
Are you really way2old? Thanks for the suggestion. That could be the problem. From what I have found, it is a real pain to replace and the gauge must also be replaced because they are calibrated together. Sounds like a real headache. Think I'll continue to drive 250 miles and filler up.
Old 07-31-2006 | 10:39 AM
94 4x4 ranger's Avatar
You can follow the wires from the tank to make sure they are not chaffed,grounding and make shure there thight at the connections.
Old 08-07-2006 | 09:54 PM
way2old's Avatar
Yes, I am really way2old!!!!!!!!!!!!!![8D]
PDEvans
01-22-2007 02:13 AM
cruzer46
12-18-2006 07:18 PM
razorbacker
11-30-2006 01:17 AM
jesus20051
08-11-2006 12:51 AM
