Head Gasket Trouble. HELP!
Old 08-29-2012 | 12:38 PM
thexlo8ers's Avatar
Originally Posted by fjaen
yea, I liked your idea with the finger on the hole, its just hard to reach and crank at the same time, and as I likely won't have any help, I felt this also would work, because it would not be hard to crank on the exhaust stroke as the valve is open and it would be easy to turn over. I would only stop with it became difficult, then insert the screwdriver to determine when i've reached the top.
great ideas. but what if this doesn't fix it... am I screwed here?
With your finger over the plug hole crank the engine over with the starter. I guess I didn't make that clear. Crank engine in short bursts, and stop cranking right when you feel the air pushed out. Most likely you'll over shoot zero degrees, and need to back the crank by hand a little. Use a screwdrive to find when the piston is at the top of the cylinder since there is no mark on the pully.
Unless you hook up a remote starter switch you will need a second person to perform this procedure.
  #12
Old 08-29-2012 | 12:43 PM
grindman's Avatar
have you ever heard of a remote starter switch? they allow you to move around some while reaching for that hole.
  #13
Old 08-30-2012 | 02:56 AM
fjaen's Avatar
yep. distributor was on backwards. fixed! Thanks! Runs great!
  #14
Old 08-30-2012 | 04:03 AM
thexlo8ers's Avatar
Thumbs up
Awesome !!!
  #15
Old 08-30-2012 | 05:35 PM
grindman's Avatar
good luck with it now that you fixed it and btw good job you saved yourself a small fortune
bgraef
11-10-2010 11:12 PM
bgraef
09-30-2010 07:27 AM
mike0179
04-25-2007 07:25 AM
JMH
03-26-2007 05:26 PM
JohnNetbee
08-01-2006 10:34 PM
