Key less entry
Old 02-12-2009 | 08:48 AM
Henry J Ford's Avatar
Default Key less entry
Can anyone tell me on a 2000 ford Taurus as far as setting the code for the buttons on the drivers door (key less entry) .
There's a procedure for the code setting in the book but it says there is a tag on the computer that will give the present code that the car is set up with I guess from the factory.
My problem is finding the computer that is mentioned without tearing into the car. Can anyone tell me the location of the computer (ECM) in the 2000 Taurus and if that is what they are referring to?
Is this the one under the driver seat? Anything I should or shouldn't do when resetting the codes?
Thanks for any info.
Old 02-26-2009 | 08:57 PM
silvershadow99's Avatar
Default Try this
Look behind the instument panel to the left of the brake pedal....I'm not talking about tearing anything out, you just have to wedge yourself onto the driver side floor to look up. There should be a small module up there that has some wires coming out of it. On it you shold see 5 numbers. That's the factory code.
Old 02-27-2009 | 08:16 AM
Thanks, I'll have a look.
trev0006
08-19-2013 07:51 AM
BarbeeFM
04-05-2010 05:02 PM
FordTruckGuy234
09-20-2009 05:14 PM
FordTruckGuy234
09-20-2009 04:56 AM
danny88
10-10-2006 04:36 PM
