p1131 a week after...
Old 09-02-2010 | 10:19 PM
Gasman_66's Avatar
Default p1131 a week after...
...changing the sensor & sync unit too! Sorry, camshaft. Went to town for an AZ test( & me a dentist appt.....lovely...lol) & there test came up w/p1131. I HAVE researched some & I guess its a cyl. 1 problem. Are the cyl. 1 sensor wires part of that " cluster F***" of wires above the CS sync??? I`d appreciate knowing where to look & any more info! Hey, I`m not mad this time, dentist gives me valium for SHOT visits....LOL!!!
Once again, Thanx ahead of time!!! GAS
Old 09-09-2010 | 04:37 PM
way2old's Avatar
P1131 is for the O2 sensor, not the cylinders. It is possible the wires were disturbed, but more than likely it is a failed sensor. Here is short description__
P1130 - Lack of HO2S-11 Switch, Fuel Trim at Limit The HEGO Sensor is monitored for switching. The test fails when the HO2S fails to switch due to circuit or fuel at or exceeding a calibrated limit. Electrical:
Short to VPWR in harness or HO2S
Water in harness connector
Open/Shorted HO2S circuit
Corrosion or poor mating terminals and wiring
Damaged HO2S
Damaged PCM
Fuel System:
Excessive fuel pressure
Leaking/contaminated fuel injectors
Leaking fuel pressure regulator
Low fuel pressure or running out of fuel
Vapor recovery system
Induction System:
Air leaks after the MAF
Vacuum Leaks
PCV system
Improperly seated engine oil dipstick
EGR System:
Leaking gasket
Stuck EGR valve
Leaking diaphragm or EVR
Base Engine:
Oil overfill
Cam timing
Cylinder compression
Exhaust leaks before or near the HO2S(s)
A fuel control HO2S PID switching across 0.45 volt from 0.2 to 0.9 volt indicates a normal switching HO2S.
P1131 - Lack of HO2S-11 Switch, Sensor Indicates Lean A HEGO sensor indicating lean at the end of a test is trying to correct for an over-rich condition. The test fails when the fuel control system no longer detects switching for a calibrated amount of time. See Possible Causes for DTC P1130
Tucker
02-02-2009 04:36 PM
Tucker
02-02-2009 04:25 PM
idogdou
01-18-2009 08:05 PM
mar7
11-12-2008 10:04 PM
hermtm2
02-26-2008 09:54 AM
