power windows/door panels
I had a problem with my driverside power window.I rolled down but wouldn't go back up. I messed with some wires inside the door panel ,looked for the fuse .no go. i tried later that night and it worked .any ideas?
Ford is infamous for master door switches failing. Since it started working again, I would look at the switch. If you are4 mechanically inclined and have patience, you can take the switch apart and clean the contacts. It is free, just costs a little time.
ikjones
08-13-2008 01:36 AM
Alex
12-04-2007 07:40 PM
partsman454
07-17-2005 09:55 PM
