remote programming
remote programming
hi all the remote key thing you know the thing you push the button on and it opens the doors and disarms the alarm is all worn out. works if you tap it. i can buy a replacement on ebay but how do i program it. for my 1997 ford taurus with base motor.
RE: remote programming
Turn ignition key off and on 8 times fairly quickly. Leave in the on position. The door locks should lock and unlock. Then press either button on the remote. The locks should work. Good luck.
Will this procedure work for a 2006 Taurus SE ? I don't want to do it wrong and lose the programming for the fob that currently works.
I tried to add a second fob in with a genysis scan tool but it did not have a special function to perform this.
How do I add a second ignition key?
93Miata
11-11-2005 04:42 PM
