tailight bulb replacement
Old 02-05-2008 | 05:14 PM
paultech6's Avatar
Default tailight bulb replacement
2oo1 Taurus left side bulb. I believe I go behind trunk cover and have to remove the three nuts on the long screws to pull assembly off car to change bulb.
I cant believe you cannot pull it out the rear of assembly .
I hope iam on the right track for replacing bulb I believe is a 3157
Any help would be appreciated
Thanks Paul
Old 02-05-2008 | 05:27 PM
94Blk5.0's Avatar
Default RE: tailight bulb replacement
You mean the bulb would come out of the connector, or the bulb & connector will not come out of the tail light housing?
The connector should be a quarter turn and pop right out , I believe the bulb pulls right out of the connector, if not try a gentle 1/4 turn.
Old 02-05-2008 | 05:45 PM
Your are on the right track..
Remove the 3 nuts and pull the assembly out.. The Stop/Tail/Brake is 3157..
Old 02-05-2008 | 05:56 PM
paultech6's Avatar
Thanks hayapower for confirming your a big help
Thanks Paul
tmontemayer
09-04-2011 01:56 PM
dshardaway
03-16-2010 09:25 AM
rescuemedic13
02-01-2010 11:32 AM
mtroofer
12-26-2009 01:25 PM
crownvic06
01-20-2006 09:17 PM
Quick Reply: tailight bulb replacement
