taurus will not start
Old 08-13-2009 | 02:23 PM
carney's Avatar
Default taurus will not start
HI, I have a 94 Taurus 3.8. It quick without warning. Have installed new fuel pump and new power trane control module (the one that mounts over the radiator) the engine will run if a little gas is put into the air intake so I know i got fire. The pump is running and fuel is in the rails and plenty of pressure out from the bleeder on the rail. Seems that the gas is not getting through the injectors. Any help? Also I have checked all the fuses Thanks Rick rickstafford87@yahoo.com
Old 08-16-2009 | 12:13 AM
carney's Avatar
Default Fixed the problem
The 94 Taraus is fixed! After serching and getting all kinds of advice for a month I tryed something today. Hearing of so many fuel injected problems caused by faulty ground I ran a wire from the neg side of battery and tapped into the ground wire of the power trane module and presto it runs great.
Old 08-16-2009 | 11:01 AM
Thanks for the update/fix..
bbeaufordf150
02-03-2009 02:38 PM
south1982
01-16-2009 06:47 AM
NYCArmyWife
11-16-2008 12:29 PM
girby01
05-04-2008 11:04 AM
solve
08-07-2005 07:24 AM
Quick Reply: taurus will not start
