Windsheild Washer
Windsheild Washer
My windshield washer is not spraying any fluid. The pump is still making is customary whine, and I've made sure the connector has been cleaned and properly seated. Is there a way to know if the washer/coolant reservoir needs to be replaced (motor attached) or, if there is a way to determine where a clog or break in the hose exists?
Thanks
Larry
Thanks
Larry
RE: Windsheild Washer
Thanks, I'll give it a try.
I also read on another thread that someone found that two different types of washer fluid
ended up mixing and gelling, then clogging up the intake on the pump.
But I'll start with the lesser of the two evils.
2006, clog, ford, freestyle, line, nozzle, nozzles2006, ranger, reservoir, spray, taurus, washer, washercoolant, windsheild, windshield
