Ford Tempo/Probe These small cars offered a sporty feel and affordable price.
88 Ford Tempo Stuttering
Old 08-29-2013 | 02:16 PM
deviant's Avatar
Default 88 Ford Tempo Stuttering
Engine stutters when gas pedal is pressed. i assumed it was either the fuel filter or the fuel pump. Have replaced both and it is still doing it. It gets really bad when going up hills but seems fine on straights as long as u don't push down on gas to much. Any thoughts or ideas would be appreciated. My next step was going to be changing spark plugs and wires, but i would think that if it where one of those u would notice it even at idle.
Old 08-29-2013 | 04:00 PM
bluewind's Avatar
To check the spark plugs and wires:
In the night, idle the engine and spray water all over the engine bay. If you see sparks flying it's time to replace plugs, wires and maybe rotor and cap.
Or take out the spark plugs and inspect them.
Also look for vacuum leaks, clean the throttle body and MAF sensor.
sandman2701
12-20-2008 11:23 PM
charles_tint
08-07-2008 10:39 PM
RealFnCool
06-13-2008 10:08 PM
brittainmcneil
12-29-2006 02:56 AM
estraw
06-30-2006 07:21 PM
