4.6 knock
There could be a few reasons for what some may describe as a knocking sound.
A rod knock
Main bearing knock
Hard valve tap
Possible cracked flex plate on flywheel.
You could have good oil pressure with any of the above.
Sometimes a trained ear can be fooled too, the object is to rule them out one at a time.
There are various methods to verify some and others have to be pinned down to be sure.
If anti freeze gets on a fan belt it can produce what sounds like a knock sometimes too
With a T Bird, the question of regular oil changes shouldn't even come up,, we hope.
A rod knock
Main bearing knock
Hard valve tap
Use a stethoscope to pinpoint the area of the engine sourcing the knock.You can't rely on the dash oil pressure gauge, it's an idiot gauge which will deflect in one position whether the pressure is 6 or 40 psi. You need to use an actual pressure gauge if you want to determine actual pressure. You did not mention the weight of oil you are using.
