95 Thunderbird Breaks
I have a 95 Ford Thunderbird. Doing the fromt breaks for the first time. What kind of tool do I use to removed the lower caliper bolt, so I can swing it up and take out the pads. It isn't a bolt, it has a STAR shape??
Thanks.
Thanks.
RE: 95 Thunderbird Breaks
Some calipers need both bolts removed to come off easily. To push the pads apart you'll need a pad spreader (or a large C-clamp if you're very careful) - carefully crack loose the bleeder screw first to allow opening while pushing the piston back with the pad spreader and eliminating backward pressure which can damage brake parts on newer cars - close the bleeder as soon as you stop turning the spreader screw. Add some fresh fluid when you're done. You just learned the better way - it reduces chance of damage and adds fresh fluid (which extends fluid life). Bleed the brakes when you're done if you think you opened the bleeder screw too long.
