Automatic Seatbelt Problems
Old 01-05-2008 | 02:35 PM
DenD76's Avatar
Default Automatic Seatbelt Problems
Hi everyone,
I have a 91 Thunderbird with the automatic seatbelts. Recently the seatbelt has stopped working. It is stuck in the foreward position on the track, so that it currently is not functional. I removed some of the interior pannels on the car to see if I could access the mechanism, but couldn't find the problem. Has anyone had any experience with these. I really don't care if I can get it working or not. I would be happy if I could just slide the mechanism from its current foreward position to the rear position (where it would normally be when driving). Then I could just manually connect the belt whe driving. I am probably getting a new car in about 4-6 months, and don't want to spend the money to replace the whole unit.
Old 01-14-2008 | 04:33 PM
illegalimmigrant's Avatar
Default RE: Automatic Seatbelt Problems
HAVE YOU EVER NOTICED THAT ALL THESE FORUMS TALK ABOUT ALL THE PROBLEMS? IT IS BECAUSE.,........
Old 01-15-2008 | 09:53 AM
oldtimer35's Avatar
You probably have a limit switch out on the belt. It tells the module if it is in the forward or rear stop of the trac.
M16sailor
01-06-2008 11:58 PM
rustbucket89
02-18-2007 04:11 AM
minimoe
02-10-2007 12:31 PM
jeremy819
06-23-2006 12:48 PM
ormalingen
12-05-2005 01:45 AM
