ignition problem
Old 01-28-2006 | 08:11 PM
krazydawg40's Avatar
Default ignition problem
replace the switch on a 95 thinderbird still nothing happening any suggestions thanks is there something loose in the colum thanks
Old 03-28-2007 | 05:58 PM
goinstrong's Avatar
Default RE: ignition problem
First check take off and clean cattery cables and terminals and put back on. Then check battery has power. Then disconnect a battery cable again and remove starter to test it. If starter is OK put it back and cable back on. Next check fuses and fusible links. If it doesn't crank - do you have power? Enough power for headlights? Does starter click under hood of car?
damonlathe
04-11-2007 09:11 PM
SleeperFan
02-09-2007 02:05 PM
bighueyy2k2
10-12-2006 11:58 PM
riska720
10-26-2005 05:20 PM
highpowerd2003
08-29-2005 11:56 PM
