Not holding a charge to start!
My 1990 ford thunderbird v6 is not starting cosistantly. I had the battery checked and it checked good at 13.5. So i took it home and removed the hot cable to the battery. It continued to run. Doea this tell me the alternator is good? What could be drawing on the battery while it sits , not running?? Or did i get a bogus battery test?? the dude seemed clueless. what should i do next??
RE: Not holding a charge to start!
Was the test done with a multimeter or a real battery tester. My old battery showed good voltage, but when the tester was put on it showed low amps, meaning the battery was toast.
Yep, sounds like a good alternator to me. Do you have any aftermarket electronics set up on the battery side of the system, (as opposed to auxilary when it gets power when the key is turned)
Over time (days/weeks,etc.) clock memory wires can drain a battery stone dead. Why don't they have switches???? Any how did you leave it run without the positive cable for3 or more minutes? Some alternators hang on pretty nice withone jumped/broken brush - but don't charge for s*** over time.If the battery's over 3 or 4 years old it's probably a good thing to start with a new one of those first. Keep in mind volts aren't as important as amps. Now before you run to buy a battery - clean the cable ends and battery posts 'till they shine and check that BOTH ends of EACH cable are tight and try again.
PlatinumCrew
08-30-2012 04:46 PM
