removal of gas tank
Old 11-08-2006 | 02:55 PM
cubsrule2406's Avatar
Default removal of gas tank
i need to know how to remove the gas tank from my 1990 Ford Thunderbird
Old 03-28-2007 | 06:44 PM
goinstrong's Avatar
Default RE: removal of gas tank
Why? The fuel filter isn't in the tank. Sorry, I shouldn't question - must be a shot pump right? Well - first - is it a rear or center (under passenger seats) mounted tank? First you should have the ***-end up on ramps. Then you need to depressurize the fuel system and remove the battery cable(s). Then you must empty the fuel tank of gas. Then you uncouple the fuel lines with your uncoupling tool (spring expander),etc. (Make sure your garage door is open for the gas smell). Then put a garage jack with a fairly wide board on it under the center of the tank (but not under the tank straps). Then -if now possible- unplug the electrical connector (else wait 'till the tank is dropped a little). Next remove the tank strap bolts and pull them out under the tank. Slowly drop tank and remove electrical connector if not already done.
stacie4171
12-21-2012 12:54 PM
BonesMachine
11-24-2010 01:58 PM
THEGOOSE
02-22-2009 11:45 PM
yoda13
09-05-2006 03:41 AM
saudioguy
06-08-2006 06:28 AM
