"Rear Anti-Lock Brake" light
RE: "Rear Anti-Lock Brake" light
check to see if the brake fluid is up to max in the master cylinder. also check the inside of the rear wheels to see if they are wet with brake fluid. if so you may have a leaking wheel cylinder that needs to be replaced. let me know what you find. james
It also may be the rear wheel speed sensor. These are known for failing. It is licated on top of the rear end housing. Click here. This page is for removal and replacement of the rear wheel sensor. Click here for a page to diagnose the ABS system.
aangel
01-16-2009 03:01 PM
JohnnyFord
09-12-2007 11:18 AM
JohnnyFord
09-07-2007 09:34 AM
rodav8
07-02-2007 11:41 AM
