'01 Lincoln LS-V8 Ignition coils
Old 01-11-2008 | 11:29 PM
monkeynutz's Avatar
Default '01 Lincoln LS-V8 Ignition coils
Hello all. New member here. I have a '01 Lincoln LS, 3.9L-V8, 70K miles, and am in the process of dropping the 3rd of 8 COP ignition coils in the last 5k miles. It is my understanding that this is common with this engine at this age. I don't want to drop another $400 at the dealer, especially if this is going to happen, presumably, 5 more times. I have a good OBD-II scanner, but presently am not getting the expected p03XX trouble code, so that I can ID the bad cylinder number. I understand that there is a threshold value in the misfire counter before it triggers a DTC, so I am waiting to accumulate the necessary misfires. Is there another way? Is there a way to access the raw misfire count prior to a DTC?
A related question: I understand that the cylinder number arrangement changed in 2002. I would like to confirm the pre-2002 arrangement. I have it #1 thru #4 front-to-rear on the passenger side, and #5 thru #8 front-to-rear on the driver's side. Can anyone confirm? Thanks!
Old 01-15-2008 | 01:05 AM
snmfffrogel's Avatar
Default RE: '01 Lincoln LS-V8 Ignition coils
You can monitor mode 6 data with a high end scantool to see marginal misfires. The cylinder numbering has'nt changed you are correct with the numbering
Old 01-15-2008 | 01:08 AM
Coil failure can be caused by water intrusion into the spark plug well, causing a secondary short to ground. When replacing coils put dielectric grease on spark plug boot. Also craked or dry rotted coil boots can cause misfires under heavy loads.
Old 01-15-2008 | 02:07 AM
monkeynutz's Avatar
Thanks for the good info... My scanner is plain text type, but not "high end", but I can get use of a better one. Have dielectric grease and spare coil on hand... Thanks again!
renegaderob18
01-05-2014 04:17 PM
mnwhiterose
04-05-2007 10:42 PM
1995_4.0
06-02-2006 04:39 PM
expohull
01-19-2006 04:31 PM
mikeinconn
05-12-2004 09:35 AM
