01 windstar a/c
01 windstar a/c
After I changed the plugs on my wifes '01 Windstar I noticed that the A/C was only blowing from the defroster. I figured that I knocked a vacuum line loose and sure enough I did. The problem is that I can't seem to figure out where it goes. It is the red vacuum line on the passenger side and behind the engine. Anyone know where the port is?
Thanks,
Sean
Thanks,
Sean
RE: 01 windstar a/c
yes on the passenger side almost at the fire wall .it is hard to see without a mirror it has a little black rubber elbow.if your piece is just the hose without the elbow means it broke off which is pretty common for them just look for the elbow part you will probably need to splice a little piece in if too short.ok
