'02 Taurus SE possible electrical problem
Old 08-09-2006 | 02:39 AM
pucknut's Avatar
Default '02 Taurus SE possible electrical problem
when all doors are closed, dome light and side mirror puddle lamps (lights under both outside mirrors) stay lit.......(disconnected dome bulb and wires on puddle lights, so they wouldnt kill battery)......i have reset relay #1 under driver side to no avail (real pain to take out)......going to try swapping relay #2 with relay #1 to see if it clears......someone mentioned that prob could possibly be in door latch..........can anybody give me any suggestions as to what might be my problem?......thank you in advance
Old 08-09-2006 | 12:43 PM
Mulletman's Avatar
Default RE: '02 Taurus SE possible electrical problem
Take a good penetrating oil like PB Blaster. Start with the driver's door and lubricate the latch. Start slamming the door open and clesed repeatedly. Do this too all doors and if you are lucky, you will find the door with the bad door ajar switch.
Change the switch in the latch. Not a fun job, but can be done with regular tools and alot of patience.
Old 05-27-2012 | 02:27 AM
automanix's Avatar
Lubrication would definitely help but take it to the service center and get the sensors checked. There could be possible wear and tear in them..
soraxcloud
04-29-2014 10:55 PM
rickcaspari
02-25-2014 02:37 AM
synthetic003
09-23-2010 03:27 AM
chiefarchi85
04-07-2009 05:09 AM
ronniet41
08-20-2008 06:08 PM
