03 Duratec overheating
Old 08-06-2009 | 05:21 AM
Use Common Sense's Avatar
That's not always the case. Depends on where a head gasket leak is and how far it has or will progress. I replaced the head gaskets on my 94 Sable's 3.8L due to exhaust breaching the gasket (tested for exhaust in the coolant and it was present). When I pulled the heads, only one cylinder had the gasket starting to fail. The way that it was failing (gasket being squeezed into the cylinder) was a partial failure causing only a cylinder to coolant failure.
askedofgod
07-18-2015 11:53 AM
JoeFed
05-17-2007 07:20 PM
jerry stastny ford
10-31-2006 03:43 PM
jerry stastny ford
10-30-2006 07:48 PM
IPPfast
08-10-2005 03:00 PM
Quick Reply: 03 Duratec overheating
