'03 Explorer Differential
Old 06-15-2012 | 10:15 PM
Eng11's Avatar
Default '03 Explorer Differential
I have a 2003 Ford Explorer, 4wd, 4.6 cu in, 5 spd auto. I'm looking to replace the rear differential oil. The Owner's manual specifies 75W-140 synthetic, however the differential case casting has 75W90 cast into it. The tag bolted to the differential has a series of numbers and an L, so I'm assuming it's a limited slip. Any suggestions as to which oil is correct?
Old 06-16-2012 | 05:08 AM
Usually if you follow the owner's manual you will be OK.
You can purchase the additive and add it for limited slip.
If you provide the vin to a Ford dealer parts dept , they should be able to tell you what is in the vehicle and have the additive if you need it.
Eng11
06-15-2012 10:35 PM
ra_dost
04-30-2007 08:53 PM
96explorerXLT
04-21-2006 08:28 AM
jbw1216
03-05-2006 01:37 AM
Ramtour2
10-12-2005 12:41 PM
