04 Freestar
Here's a couple of things to check. Need three things for asn engine to run. Air, fuel and spark. Unless you have a pack of squirels, you could rule out air. The next thing would be to check and ensure that the fuel pump runs and pumps up to the proper pressure before turning off. If the pump works and you have the proper fuel pressure, then you need to look at spark. You could have a failed could have a failed coil pack. I would also check to ensure that all of your grounds are making good contack. There are several of them under the front black cover on both sides of the radiator suport. Don't forget to check the on by the A/C dryer/receiver bolted to the right side strut tower. Let us know where you stand at this point and we'll go from there, probably into crank sensors and such.
toaster
07-17-2005 03:19 PM
