06 Ford 500 P0340
Old 08-07-2018 | 11:22 PM
Vandey42's Avatar
Default 06 Ford 500 P0340
2006 five hundred with active P0340 CMP fault code. Sensor has already been replaced. Any tips/help is appreciated.
Old 08-09-2018 | 02:08 PM
Sometimes connections/plugs at alternator can instigate this code, check if they are clean and tight.
Old 08-11-2018 | 05:24 PM
Vandey42's Avatar
Default P0340
Checked connections at alternator, looked ok. Also load tested the wiring from the sensor to the PCM and that’s ok as well. It’s also running rough and seems to be pre-detonating in the intake manifold. Thinking the timing chain possibly skipped a tooth?
Durfey21
03-13-2020 02:01 PM
Nine8
02-09-2014 06:02 AM
tonywingrove
06-11-2011 10:04 PM
69BirdWatcher
12-04-2010 11:26 PM
lthacker
03-05-2007 10:59 PM
Quick Reply: 06 Ford 500 P0340
