07 Escape turn signal
Old 06-01-2014 | 10:33 PM
58bowty's Avatar
Question 07 Escape turn signal
Hi,
I have a 2007 Escape with a turn signal problem. It was intermittent but is now permanent. The left rear does not work. The indicator flashes fast and the front bulb works but not the rear. I checked the bulb and it's OK. I also checked for voltage at the rear socket and no voltage is present. I checked the ground at the rear socket and it's good. I'm guessing I have a bad connection somewhere but not sure where to look. I did try moving the steering column up and down while trying the signal but that did not make a difference. Any help greatly appreciated.
Thanks!
Ty
Old 06-02-2014 | 09:30 AM
Welcome to site..
The R&L share a ground so that would eliminate a grounding issue. If you have no power distribution at the lamp connector next step may be to check/back probe the left turn circuit at the Smart Junction Box connector. If you have nothing there, chances are its a problem within the SJB..
Old 06-03-2014 | 10:43 PM
58bowty's Avatar
Thanks Hayapower! I'm new to this vehicle. Where is the SJB located? I'll probably need to get a wiring diagram to follow up on this. Thanks for your help and glad to be aboard.
Ty
Old 06-03-2014 | 11:32 PM
Centered under the lower dash. I can send you diagrams and connector views if you need them..
Old 06-04-2014 | 07:32 AM
58bowty's Avatar
I would sure appreciate that Hayapower. I would guess that is the first connection coming from the tail light. Thanks so much for your help!
Ty
Glowbug
01-28-2022 12:43 PM
Checkedwood
10-16-2009 02:36 PM
pixleyyy
03-27-2007 11:08 PM
harlem
01-16-2006 03:35 AM
bingermann
10-31-2005 01:36 PM
Quick Reply: 07 Escape turn signal
