1959 Ford turn signal issue
Old 06-04-2012 | 07:36 PM
Catch and Eat's Avatar
Default 1959 Ford turn signal issue
59 Galaxy 500 turn signals will not work. Tried tracking down a flasher unit and cannot find one under the dash. Anyone with any ideas how to go about solving this issue? Do I need to replace the switch in the column? Thanks
Old 06-05-2012 | 03:04 PM
Capt Video's Avatar
Pretty sure there should be a Flasher there somewhere, did you check the fuse panel?
Old 06-05-2012 | 06:40 PM
I have looked everywhere under the dash. There is not a fuse panel in this vintage of car, only a few in line fuses. I found the horn relay in the engine compartment but not a turn signal relay. I have traced the wiring and do not seem to have power going up the column to the switch. Not sure if I am testing it correctly though.
Old 06-06-2012 | 11:14 AM
I found it. Someone had removed the flasher unit. Crazy. It's located between the heater controls and the radio up high.
Glowbug
01-28-2022 01:43 PM
Tslayer
04-03-2015 09:21 AM
Zadias
10-13-2009 10:17 AM
Alfonso
10-11-2006 05:43 PM
cjnprntr
07-02-2005 09:59 PM
