1973 ford f250 390 engine
Old 09-26-2013 | 09:15 PM
BullElk79's Avatar
Unhappy 1973 ford f250 390 engine
My truck will start and run fine for bout 2 min then just turn off sometimes it will start back up other times it will just turn over.if i let it sit over night it will start right up and do the same thing.It has a Mallory unilite distributor put in a new coil new edelbrock carb.This is driving me crazy please help
Old 09-26-2013 | 09:19 PM
BullElk79's Avatar
All this started a week after it overheated
Old 09-26-2013 | 09:48 PM
If you check for spark at the time it will not start it should provide a path to continue checking further.
Old 09-26-2013 | 10:04 PM
BullElk79's Avatar
At the time there isn't spark
Old 09-27-2013 | 07:47 AM
Rusty Baker's Avatar
Originally Posted by CasseySwartout
is the idea for getting the right suggestion and solution from an expert in form of any automobile techy will not help in making the trouble sorted out .. what i guess it will
What?
Old 09-27-2013 | 08:15 AM
BullElk79's Avatar
Im looking for advice on what's wrong.Something in the distributor?
Old 09-27-2013 | 08:28 AM
Don't know if this is the problem, but there should be a pick-up coil in the distributor that sends a signal to the module that the engine is turning over. You might check the wires coming out of the dist to verify the pick-up coil has continuity.
Old 09-27-2013 | 09:26 AM
BullElk79's Avatar
Even on a Mallory unilite distributor.Electrical stuff is kinda where im alil retarded
Old 09-27-2013 | 10:44 PM
BullElk79's Avatar
Put in new plugs and wires tonight started ran smooth then after bout a min died and just. Cranked gonna try the pickup coil in the distributor in the morning got to dark tonight
Old 09-29-2013 | 01:34 PM
BullElk79's Avatar
Fixed it needed a new Mallory led module. Thanks for the help
stewart390
08-27-2019 04:24 PM
DJenkinsABQ
08-17-2015 10:04 AM
amiehuffines
09-06-2012 08:19 PM
btmrjames
10-31-2010 12:04 PM
cariboo4x4
07-05-2010 01:37 AM
