1989 Ford Aerostar (Electrical / Lighting Systems - Malfunction)
Old 01-18-2006 | 05:24 PM
jesus20051's Avatar
Default 1989 Ford Aerostar (Electrical / Lighting Systems - Malfunction)
When I turn my van on the panel lights (acceleration, speed, gas) its ok, its on, but when I turn my head lights it goes off, but I can see verry dark that stil working (the acceleration and speed, and temp, gas). My panel its digital.
And when I turn the head lights off the panel come back on (the lights)
can you help me?"
Old 01-19-2006 | 01:47 AM
bosshoss's Avatar
Default RE: 1989 Ford Aerostar (Electrical / Lighting Systems - Malfunction)
Hey.
Just a quick thought, but try checking your dimmer switch position. Turn it all the way till the inside light comes on, then back just enough to turn of the light. Your dash lights should be at the brightest. Let us know what happens.
Old 01-19-2006 | 12:06 PM
jesus20051's Avatar
I did , nothing happent
Old 01-19-2006 | 09:33 PM
way2old's Avatar
Look out by the battery and there is a small wire hooked to the fender. It is a body ground. The headlights run through it. If the ground is bad, it could be that the headlights are taking the ground from your dash panel. If it is OK, you may need to remove the instrument cluster and check the grounds in there.
Old 01-19-2006 | 11:05 PM
jesus20051's Avatar
can you explen to me more especificly? my english is not that good.
this body ground is from battery?
where is this instrument cluster
thank you and sorry
Old 01-20-2006 | 10:11 PM
way2old's Avatar
There is a small wire from the negative battery post that goes over to the fender on a small bolt. This is the body ground that helps the lights towork properly. The instrument cluster is the panel where you do not have the lights working properly. No problem here. Hope this is a better explanation for you.
Old 08-11-2006 | 12:51 AM
razorbacker's Avatar
I have a similar problem on a 1996 Ford Explorer. My instrument panel lights many times are out when I start the engine. The turn signals will not work, but the signal indicators are illuminated constantly. The headlamps function properly too. Some times a good bump in the road will cause the panel to work properly. Any further suggestions?
FloridaE150
03-15-2013 03:44 PM
rlewis356
05-02-2012 01:49 PM
jbish44
02-01-2007 05:30 PM
razorbacker
11-30-2006 01:17 AM
sanddman
03-04-2006 02:18 AM
