1999 e250 starts and dies
Old 07-12-2011 | 10:00 AM
tjrusty's Avatar
Default 1999 e250 starts and dies
My 99 ford e250 with a5.4 start and dies immediate I changed the fuel filter and fuel pump still the same thing fuel pressure is 35-40 psi thought was cat but never smelled and when it tries to start I do get exhaust out the tail pipe any thought help would be great thanks. Todd. Can email me at tjrusty@aol.com
Old 07-12-2011 | 06:58 PM
way2old's Avatar
Have you checked the Idle Air Control motor? If you can give it a little gas and it keep running, more than likely it is the IAC.
Old 07-13-2011 | 08:13 AM
tjrusty's Avatar
Default e250
Found problem it was the sensors that are by the filter cleaned I believe its called mas or map. Cleaned and running great.
Old 07-13-2011 | 06:55 PM
way2old's Avatar
Thanks for the fix reply. We have too many that never respond. Thank you.
goatsauce
04-15-2013 09:32 PM
WIECHWRX
05-05-2011 12:58 PM
snapper1d
12-10-2010 10:26 AM
d1badz
12-15-2008 05:48 PM
d1badz
10-30-2008 06:57 PM
