1999 Explorer Problems HELP!
Old 04-06-2010 | 11:56 AM
robris's Avatar
Default 1999 Explorer Problems HELP!
I have a 99 Exp. and the fuel pump has been replaced 2 times in the last 3 years. Now, my engine will run fine for a while then it will stall out like it is not getting fuel. It has trouble starting right after that. If it sits for a while, it will start and run fine. I had it looked at and the mechanic could not identify the problem. He thought maybe they put in the wrong fuel pump. I did replace the filter and that did not help. Any other thoughts or remedies. It is getting expensive and I am not getting anywhere. thanks in advance. rob
Old 04-08-2010 | 12:12 AM
Linus's Avatar
Robris, Not sure if it helps, but a number of years ago I had a similar problem on my '91 explorer that was difficult to diagnose. Don't remember the specifics, but turned out that that there was a heat related fault in the electrical system that once hot, prevented the fuel pump from getting enough electricty to run properly. As i recall, they replaced a wire or wiring harness and I was good to go.
kenified06
09-24-2012 07:21 PM
kepackman
11-06-2011 02:57 PM
Will
04-26-2006 11:11 PM
donkey dawn11
03-01-2006 09:37 PM
bburt2
09-11-2005 06:40 PM
Quick Reply: 1999 Explorer Problems HELP!
